Mycakers
39 -
Recent Profile Visitors
1,817 profile views
Mycakers's Achievements
New Member (2/5)
4
I don't know who was responsible for the attic. My dryer stopped drying so I checked the vent. It was packed solid with lint. I went up in the attic to remove the vent and clear it. That is when I noticed the lack of fire walls. At the time I had no idea that I would want to be a HI so I didn't think about anything other than security. I am the one who padlocked the access.
Mycakers started following Wacky Roof Shingles , Townhouse Firewall , Article: How to respond to negative reviews against your home inspection business and 2 others
The town house I lived in (IL) was a 4 unit and I could walk from one end to the other from the attic. The wife was a little upset to see a padlock installed on the access shortly after I found out. They were built in 92'.
Thanks Jim. I know NHIE is big on distractors and it never hurts to be reminded of that. There was a second half of my question. I know some of the indicators for identifying structural masonry. With anchored, I would assume you should not be able to physically see any indicators of the anchors themselves. I did some research on it and watched a few videos on the building process after I got to this question. Identifying what is NOT there, is something that I need to spend more time on. I appreciate the difference between the comprehensive NHIE text book versus the AHIT course book. It makes your thought process become more in depth as opposed to just giving you the answers like AHIT. I still cannot knock the AHIT course. I understand that it doesn't do a great job in preparing you to just hit the road or start getting calls. It did however, give me a great overview of what I am getting into. I know exactly what I need to work on and get familiar with (which is a lot). I know that I will not have a problem passing the IL state exam and that it is just the tip of the iceberg. I am trying to take all of the info from this site and as many other resources I can get my hands on to complete practice inspections. I am also gaining confidence in my ability to ask meaningful questions when I find a few ride-alongs. Thanks again.
It is the 2015 NHIE Home Inspection Manual. The question is under the Reporting Findings section if you have the book. The pic is literally the corner of a "brick" house. It is so fuzzy that you cannot rule out even fake brick paneling. I can upload a pic when I get home.
I'll need to get back to you on that when I get home from work.
I'm not sure where to park this question. I did a quick search and couldn't find anything. I was going through my NHIE text book and one of the review questions showed a picture of the corner of what appears to be a brick exterior. The pic is black and gray and kind of fuzzy. The question asks, identify this type of siding. The answer is Anchored masonry according to the answer key. Are the anchors visible with this type of brick? If not, how would you identify it and report it? Thanks in advance.
Just soffit and box vents. I have a fan also but it doesn't have a humidistat. Kitchen and bath ducts are insulated.
I do but they are on my tablet at home. I will upload them when I get off of work.
North East IL. The first snow fall was just a couple days ago. I was wondering if it might be common to get that much moisture in the attic with the crazy temperature swings we have had. I'm going to see what happens when winter sets in. Hopefully I don't have ice sickles dropping through the ceiling.
Detailed in previous posts above, I had black mold covering my attic that I needed to remove before I proceeded with my loan to buy my house. I have done everything I could do within my budget to keep heat and moisture out of my attic. I have recently sided and had all windows replaced in my all electric house with baseboard heaters. I had the siding guys cut in more holes for new soffits and installed baffles at every vent. I don't have a ridge vent but I have plenty of box vents and an attic exhaust fan. After pulling out the old insulation in my attic, sealing all holes and blowing in new insulation, I installed a range fan and bathroom fan (vented through the roof). The roof is about 8-10 years old with one layer of asphalt shingles. It recently snowed and I went up in the attic to check on things and noticed all of my sheathing is damp and at the peak of the roof there is active condensation drips. Is there anything else I can do to fix this issue or at least lessen it? Should I be thinking about a dehumidifier in the attic? TIA
Should I buy used Electrical Equipment of not!
Mycakers replied to 211kevinrichard's topic in Electrical Forum
I am on a machinist forum for my current place of employment. It is easy for me to spot them in my industry. It will take a little getting use to here. Thanks for pointing this out to me. -
What kind of project? What kind of electrical supplies? -
Gravity is a difficult concept to grasp. 😂
