I have purchased a whirlpool bath with a heater and need to understand the wiring please. The installation manual states the information below. 15 AMP DEDICATED The whirlpool should be installed on a 120 vac, GFCI circuit. The circuit should be hard-wired from the electrical power supply panel. The circuit must be a three (3) wire circuit from the electrical supply panel. A grounded neutral wire and a third wire, earth ground, are essential. Optional heater requires a separate 15 amp maximum GFCI circuit I have a double 15 amp circuit breaker, can I run 1 wire from the circuit breaker to the tub 28ft 12/3 wire, then branch that wire to 2 15amp gfi plugs? Thanks for any assistance. Sherryt[:-monkeyd
