Well, some minor diffence of opinions. Seems like without a bonding wire if the sheaths get pulled apart into a spiral or there's a poor connection with a lot of resistance it becomes like a toaster element if there's a short from hot to the sheath and a breaker fails. Guess I'll put a load circuit analyzer and at least get some impedance/resistance numbers for the ground and check for weak connections in the old wiring and install those GFCI/AFCI breakers. I found this info on another board so I'm quoting someone else. Appears to be as accurate a reason as I could find. So since there grounded outluts on the old BX are not to code do I need to replace with 2 prong or label the three prong GFCI-No equipmanent grouind?
