cynflux
cynflux's Achievements
  1. Hello, My wife and I have an apollo hydro heat system in our 1235 sq ft townhome. The past winter our apollo water heater developed a leak and had to be replaced. The weather started to get colder so we turned on our heat and it was not working. I have had several people come out to look at the unit. One person said that the water heater temp is not high enough. I turned it up, but still doesn't work. Another person came out and said the heat pump needed to be replaced. When he came to replace it, he said that the bolts on the heat pump were very rusty and could not take off the bolts. He recommended another person who could solder out the old heat pump and put a new one in. I just had a hvac guy go out to our house and he said heat pump is fine, but water is not hot enough. HVAC also mentioned that unit is on its last leg and needs to be replaced. We can't afford a new unit and I don't think we will get approved for financing. Not a good experience with this Apollo unit.
