Stephen Lagueux
    183
    Canada
    Certified Home Inspector
Recent Profile Visitors
Stephen Lagueux's Achievements
Member
Member (3/5)
  1. I know, I know, I misunderstood the concept [:-banghea and got carried away..... arghhhhhh. now looking for a hole to crawl in.... Click to Enlarge 30.33 KB
  2. I checked a few receptacles today for bootleg grounding in a 1974 home and found a few as seen on the pictures. I even got a 120 reading when checked the screw just for the heck of it (second pic). I also checked the range and dryer receptacles. As expected, I got the 240 v. reading when I checked the 2 lines and 120 v. when checked seperatly with the neutral. Where it gets interresting is, I also got a 120 v. reading when I checked the lines with the ground. Now, the way to get this reading is if the ground conductor is bonded with the neutral in the panel or, the receptacles were previously wired using 3 wire cables and someone changed the receptacle to accomodate newer ranges and bootleged the ground. The issue that I have with this is that the appliance's body, being most likely bonded, could get energized if a voltage surge occurs and would pose a serious risk of electric shock. (same concerns on any bootleged 120 v. outlets). What about you guys, what do you think of the energized ground on the 240 volts receptacles? Click to Enlarge 25.29 KB Click to Enlarge 24.33 KB Click to Enlarge 27.39 KB Click to Enlarge 24.53 KB
  3. Thanks for the info. I'm no chimney specialist. WETT certification should be my next formation.
  4. thanks for the link John, I appreciate.
  5. For the Cannucks out there, I can't find anything in the Canadian Building Code for brick support (lenghtwise). Anything? How about on the US side, what does the code say? Click to Enlarge 56.46 KB
  6. yes, a 3 ft minimum height is required and the chimney should be 2 ft higher than any structure in a 10 ft radius. In that case, I suspect the taller chimney was installed after which would explain the height difference and the roof vents are brand new.
  7. you're right, in that case it is not that critical and it is not really worth mentioning. The 4 ft clearance is from the manufacturer's installation guide. The vent should not be closer than 4 feet to any structure, wall, chimneys or anything that is higher.
  8. I was told by the actual owner that the previous owner used to use this closet as a wine seller and this was some kind of climate control system. Ever seen one of those? Click to Enlarge 35.62 KB
  9. That's right!! the vent requires a 4 ft clearance, thanks for reminding me.
  10. Twinhouse, what should be the proper clearance in between the 2 chimneys? The distance here is 20 inches. Click to Enlarge 70.81 KB
  11. I guess it would make sense to limit the breaker size next to the main. I'll try to contact siemens just to see what they say about it. Thanks guys.
  12. 100 amps Siemens sub panel. Beside its obvious informational role, this 25 amp. max sticker right next and, pointing to the 100 amp main breaker makes me wonder which one should'nt be there, the sticker or the breaker?? What say you? [:-banghea Click to Enlarge 45.77 KB
  13. I'll simply state the facts in the report. But on site, talking to my client, I'll tell them that it was done on a friday afternoon by someone wanting to learn...
  14. Just found this link on mechanical roof fasteners. looks pretty much like the picture, made from Firestone Tire and rubber Co. http://www.google.com/patents/EP0276708B1?cl=en
