Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > HVAC Forum >
Chromalox radiant ceiling heat?
Previous Topic: Rusted furnace flue - Topic - Next Topic: Glad they had a label maker New TopicReply to TopicShare Topic
Posted By
View Profile
Sykesville, Maryland
Currently offline offline
Thread Start First Page
[#1] Posted: 05/06/2012 - 07:39:50 AM
I inspected a ranch style home yesterday that had Chromalox radiant ceiling heat. Home was built in 1966 and I believe this is the original heating system. The current owner had added a split system A/C. Each habitable room had it's own thermostat, and all of the ceilings heated up. Other than some cracking in the ceilings from the expansion and contraction, I didn't find anything else wrong but I don't really have much info in the old memory banks on this system so I am asking if anyone can point me to anything that my client should know? I searched the CSPC website and didn't find any recalls, searched the archives here and didn't see anything. I've e-mailed Chromalox but probably won't get an answer for a few days. Any and all help appreciated.
"your home inspector shoulda seen that, hon."
View Profile
Chicago, IL
[#2] Posted: 05/06/2012 - 07:53:10 AM
They work until they don't. It's a heat trace.
Don't drive a nail into the ceiling.
Kurt in Chicago
View Profile
Gaston, Oregon
[#3] Posted: 05/06/2012 - 08:41:34 AM
They work fine.
If they stop working, an intelligent electrician can fix them. It involves finding the break, excavating the plaster, and making a simple splice.
If the owner were to use them to heat the entire house, the meter would spin very fast. Depending on what you pay for electricity, that might be costly.
If the owners want to hang a plant from the ceiling or make any other kind of hole, they can find the cables by spritzing the ceiling with water while the heat is on. The areas with the cables will dry faster, showing them the outline.
Having the cables still working is a good thing. They can heat up one room without using the heat pump to heat the whole house if they want to.
Jim Katen, Oregon
www.amipdx.com
View Profile
Chicago, IL
[#4] Posted: 05/06/2012 - 10:15:10 AM
Actually, it's two jobs. There's the fixing the break, and there's the finding someone to fix the break. It involves surgical excavation of the gypsum board, not excavation.
Don't overestimate the number of electricians competent or willing to find and fix a break.
Count on anyone other than the extremely technically handy to tell you it's not possible.
Kurt in Chicago
View Profile
[#5] Posted: 05/06/2012 - 3:36:48 PM
Thanks Gentlemen.
View Profile
Gaston, Oregon
[#6] Posted: 05/06/2012 - 5:43:31 PM
I guess it depends on how common those systems are in your area. In one little town that I work in a lot, the great majority of homes were equipped with radiant ceiling heat through the '50s, '60s, and the early part of the '70s. Every electrician in town can fix them with ease. They excavate the drywall with a hammer.
Jim Katen, Oregon
www.amipdx.com
View Profile
Chicago, IL
[#7] Posted: 05/06/2012 - 7:38:31 PM
Sure, it's small town America. People fix stuff.
We've got huge downtown towers full of the stuff; a guy could make a business out of just fixing radiant ceiling wires. No one to do it.
Kurt in Chicago
View Profile
Gaston, Oregon
[#8] Posted: 05/06/2012 - 8:01:10 PM
Sounds like an opportunity.
Jim Katen, Oregon
www.amipdx.com
View Profile
Chicago, IL
[#9] Posted: 05/06/2012 - 8:47:28 PM
There isn't a soul in Local 134 that would demean themselves by doing something so sensical.
Kurt in Chicago
View Profile
Collins, NY
[#10] Posted: 05/07/2012 - 06:30:51 AM
That's an argument against unions, not radiant ceilings.
Tom
Dr Joe Lstiburek
View Profile
Chicago, IL
[#11] Posted: 05/07/2012 - 06:58:18 AM
So, folks think resistance heat ceiling panels is a good idea?
Just curious, as I tend to think they're one of the more idiotic ideas come down the pike.
Are they smart?
Kurt in Chicago
View Profile
Gaston, Oregon
[#12] Posted: 05/07/2012 - 09:09:49 AM
Are they smart?
If the cost of electricity isn't a concern, then I'd say they're a good way to heat a house. They're very reliable, they require zero maintenance, they give room-by-room zone control, very good temperature control, and present no worries about furniture layout (as you might have with radiators or warm air systems). They give all the benefits of any radiant system but, because they're in the ceiling, you can still put thick, heavy carpets on the floor if you want. The radiant surface is never obstructed (well, unless you put big sheets of aluminum foil on your ceiling).
Really, the only drawback is cost of operation. These things are suited to places where electricity is cheap.
Jim Katen, Oregon
www.amipdx.com
View Profile
DeWitt, Mi
[#13] Posted: 05/07/2012 - 10:51:07 AM
any emf concern?
Les
View Profile
Gaston, Oregon
[#14] Posted: 05/07/2012 - 11:16:12 AM
Quote: Originally posted by Les
any emf concern?
They throw a pretty good EMF. If you believe that matters, then it's probably a concern.
Of course, it's nowhere near the concern that you'd have with an electric blanket.
Jim Katen, Oregon
www.amipdx.com
View Profile
DeWitt, Mi
[#15] Posted: 05/07/2012 - 3:01:32 PM
.............all I know is my goat's milk production was lower after I let them stay with me in the living room (that has electric cables buried in the plaster ceiling).
Les
View Profile
Chicago, IL
[#16] Posted: 05/07/2012 - 4:47:29 PM
Cheap juice out in Oregon. Expensive in Chicago. Make no sense.
Kurt in Chicago
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
